Acer Aspire V5-571 Upper Cover Replacement
  1. Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: step 1, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: step 1, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Keyboard: step 1, image 3 of 3
    • Turn off the laptop and remove the battery.
    • Remove two screws securing the Keyboard.
    • The Keyboard is held by two locking clips, under the battery. Use the sharp tip of a plastic tool to release the keyboard.
  2. Acer Aspire V5-571 Upper  Cover Replacement: step 2, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 2, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 2, image 3 of 3
  3. Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: step 3, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: step 3, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Optical Drive: step 3, image 3 of 3
    • Remove the screw securing the Optical drive and gently press the drive to show slightly as at the second pic.
    • Slide the drive to the left and remove it.
  4. Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: step 4, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: step 4, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement, Upper  Cover: step 4, image 3 of 3
    • Remove 4x phillips screws and disconnect:
    • Power On button flex cable
    • Touch pad flex cable
    • Remove 18x Phillips screws from the bottom cover.
    • Remove any memory SD Card from the Card reader.
    • Start opening with a plastic opening tool.
  5. Acer Aspire V5-571 Upper  Cover Replacement: step 5, image 1 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 5, image 2 of 3 Acer Aspire V5-571 Upper  Cover Replacement: step 5, image 3 of 3
    • Carefully separate the upper cover and remove it.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 8
All Time: 3,025
