Acer Aspire V5-571-6889 Hard Drive Replacement
  1. Acer Aspire V5-571-6889 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Hard Drive Replacement: step 2, image 1 of 1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Hard Drive Replacement: step 3, image 1 of 1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Hard Drive Replacement: step 4, image 1 of 1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Hard Drive Replacement, Remove Upper Cover: step 5, image 1 of 1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Hard Drive Replacement: step 6, image 1 of 1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
0 Comments
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 15
All Time: 687
