Acer Aspire V5-571-6889 Motherboard Replacement
  1. Acer Aspire V5-571-6889 Motherboard Replacement, Hard Drive: step 1, image 1 of 1
    • Flip laptop over so that the back is facing upward.
    • Push switch to the right.
    • Pull battery away from the laptop.
  2. Acer Aspire V5-571-6889 Motherboard Replacement: step 2, image 1 of 1
    • Use a #0 Phillips head screw driver to remove all of the screws.
  3. Acer Aspire V5-571-6889 Motherboard Replacement: step 3, image 1 of 1
    • Flip laptop back over.
    • Open the laptop.
    • Wedge a prying tool between the keyboard and laptop body seam to remove keyboard.
    • Be careful not to bend the keyboard too much or break the tabs that connect the keyboard to the laptop.
  4. Acer Aspire V5-571-6889 Motherboard Replacement: step 4, image 1 of 1
    • Gently lift keyboard.
    • Disconnect keyboard from the laptop.
  5. Acer Aspire V5-571-6889 Motherboard Replacement, Remove Upper Cover: step 5, image 1 of 1
    • Disconnect the two ribbon cables at the near left.
    • Remove six screws: ⁃ one by the left most ribbon cable connector ⁃ one mid-right center ⁃ one on the near edge left of center ⁃ three across the back
    • Use a prying tool to remove the upper cover.
  6. Acer Aspire V5-571-6889 Motherboard Replacement: step 6, image 1 of 1
    • Locate the hard drive.
    • Lift the hard drive.
    • Disconnect hard drive.
  7. Acer Aspire V5-571-6889 Motherboard Replacement, Motherboard: step 7, image 1 of 1
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm with screw attached to the Motherboard.
  8. Acer Aspire V5-571-6889 Motherboard Replacement: step 8, image 1 of 1
    Tool used on this step:
    Buy
    • Use Tweezers to remove the antenna cables attached to the Wi-Fi card.
  9. Acer Aspire V5-571-6889 Motherboard Replacement: step 9, image 1 of 1
    • Use #0 Phillips screw driver to remove the two 2.5 x 5 mm Phillips #0 screws connecting the Wi-Fi card to the Motherboard.
  10. Acer Aspire V5-571-6889 Motherboard Replacement: step 10, image 1 of 1
    • Lift and pull out the Wi-Fi card.
  11. Acer Aspire V5-571-6889 Motherboard Replacement: step 11, image 1 of 1
    • Use #0 Phillips screw driver to remove the 2.5 x 5 mm Phillips #0 screw on the CD-ROM Drive.
  12. Acer Aspire V5-571-6889 Motherboard Replacement: step 12, image 1 of 1
    • Lift and pull out the CD-ROM Drive.
  13. Acer Aspire V5-571-6889 Motherboard Replacement: step 13, image 1 of 1
    • Use #0 Phillips screw driver to remove the 2 x 3 mm Phillips #0 screw holding down CD-ROM connector.
  14. Acer Aspire V5-571-6889 Motherboard Replacement: step 14, image 1 of 1
    • Pull out the CD-ROM Drive connector.
  15. Acer Aspire V5-571-6889 Motherboard Replacement: step 15, image 1 of 2 Acer Aspire V5-571-6889 Motherboard Replacement: step 15, image 2 of 2
    • Use Tweezers to remove the tape covering the display cable connector.
    • Gently disconnect the display cable connector.
  16. Acer Aspire V5-571-6889 Motherboard Replacement: step 16, image 1 of 1
    • Gently peel back the black cloth tape holding the wires in place.
  17. Acer Aspire V5-571-6889 Motherboard Replacement: step 17, image 1 of 1
    • Gently lift Motherboard.
    • Do not remove yet. There are some connections that need to be disconnected.
  18. Acer Aspire V5-571-6889 Motherboard Replacement: step 18, image 1 of 1
    • Gently remove the connector underneath the Motherboard.
  19. Acer Aspire V5-571-6889 Motherboard Replacement: step 19, image 1 of 3 Acer Aspire V5-571-6889 Motherboard Replacement: step 19, image 2 of 3 Acer Aspire V5-571-6889 Motherboard Replacement: step 19, image 3 of 3
    • Gently disconnect the three connectors attached to the Motherboard.
  20. Acer Aspire V5-571-6889 Motherboard Replacement: step 20, image 1 of 1
    • Use #0 Philips screw driver to unscrew the three 2.5 mm x 4 mm screws connecting the CPU fan to the Motherboard.
  21. Acer Aspire V5-571-6889 Motherboard Replacement: step 21, image 1 of 1
    • The motherboard is ready to be replaced.
    • Attach the CPU fan to the new motherboard during reassembling.
Samuel Miguel
241 Reputation
1 Guide authored
IUPUI, Team S2-G4, Harley Summer 2019 Member of IUPUI, Team S2-G4, Harley Summer 2019
IUPUI-HARLEY-SU19S2G4
3 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 15
All Time: 597
