Introduction
This guide will show how to replace the motherboard if it becomes damaged or non-functional.
Use the pointed end of the spudger to slide the battery lock until the battery pops loose.
Slide the optical disc drive out of the slot to disconnect it from the motherboard.
Unscrew the main 3.5mm PH1 screw from the motherboard.
The motherboard can be replaced once disconnected from the CPU cooling fan.
Almost done!
