Acer Aspire V5-571P-6815 Touchscreen Replacement
  1. Acer Aspire V5-571P-6815 Touchscreen Replacement, Battery: step 1, image 1 of 1
    • Turn off the computer and unplug all power.
  2. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 2, image 1 of 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 2, image 2 of 2
    • Slide the locking latch to the right and hold while pulling the battery out with your other hand.
  3. Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: step 3, image 1 of 2 Acer Aspire V5-571P-6815 Touchscreen Replacement, Touchscreen: step 3, image 2 of 2
    • Insert a plastic opening tool between the screen and lid.
    • Work the plastic opening tool around the perimeter while prying upwards until the screen separates from the lid.
  4. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 4, image 1 of 1
    • Lay the screen flat down on the keyboard.
  5. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 5, image 1 of 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 5, image 2 of 2
    Tool used on this step:
    Buy
    • Remove the camera using a pair of blunt nose tweezers.
    • Peel up the adhesive tape keeping the camera's cable tied down.
  6. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 6, image 1 of 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 6, image 2 of 2
    • Remove the microphone from the motherboard with a pair of blunt nose tweezers.
    • Slide out the adhesive tape securing the microphone cable.
  7. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 7, image 1 of 3 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 7, image 2 of 3 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 7, image 3 of 3
    • Lift up the ribbon cable contained by the adhesive strip with blunt nose tweezers.
    • This will allow you to access the two black digitizer ribbons.
    • Use a spudger to flip up the retaining flap on the digitizer ribbon cable ZIF socket.
    • Pull the ribbon cables out of their sockets.
  8. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 8, image 1 of 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 8, image 2 of 2
    • Remove the board from the laptop.
  9. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 9, image 1 of 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 9, image 2 of 2
    • Use the blunt nose tweezers to peel up the adhesive on the display cable.
    • Pull on the adhesive tape to disconnect the display from the motherboard.
  10. Acer Aspire V5-571P-6815 Touchscreen Replacement: step 10, image 1 of 2 Acer Aspire V5-571P-6815 Touchscreen Replacement: step 10, image 2 of 2
    • Lift the whole strip connected to the circuit board and LCD connector. Place the strip to the side where it is not in contact with the screen.
    • Remove the whole screen from the device.
Brianna Sinder
377 Reputation
2 Guides authored
UW Tacoma, Team S1-G4, Liner Spring 2018 Member of UW Tacoma, Team S1-G4, Liner Spring 2018
UWT-LINER-S18S1G4
5 Members
8 Guides authored
One Comment
The heading of your Procedure is “Acer Aspire V5-571P-6815 Touchscreen Replacement” BUT you just opened up the entire screen.
NOTE: you didn’t separate the “TOUCH SCREEN” from the LCD screen.
This supposed to be the most important part of your procedure item ! ! ! !
PLEASE……. ******
KaivitiSingh - Reply
Past 24 Hours: 1
Past 7 Days: 6
Past 30 Days: 29
All Time: 3,432
