Acer Aspire V5-572 Bottom Cover Replacement
Video Overview
  1. Acer Aspire V5-572 Bottom Cover Replacement, Bottom Cover: step 1, image 1 of 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572 Bottom Cover Replacement: step 2, image 1 of 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572 Bottom Cover Replacement: step 3, image 1 of 3 Acer Aspire V5-572 Bottom Cover Replacement: step 3, image 2 of 3 Acer Aspire V5-572 Bottom Cover Replacement: step 3, image 3 of 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572 Bottom Cover Replacement: step 4, image 1 of 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
ZFix
194,021 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
327 Members
1,697 Guides authored
One Comment
Hello, I'm just trying to find this bottom casing -- anywhere -- and cannot seem to be able to find or purchase one. Often the wrong one comes up when I search (as evidenced by vents in the wrong places). Any ideas? Thanks in advance.
bellemcc - Reply
Past 24 Hours: 0
Past 7 Days: 5
Past 30 Days: 13
All Time: 3,984
