Acer Aspire V5-572, V5-572G Battery Replacement
Video Overview
  1. Acer Aspire V5-572, V5-572G Battery Replacement, Bottom Cover: step 1, image 1 of 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Battery Replacement: step 2, image 1 of 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Battery Replacement: step 3, image 1 of 3 Acer Aspire V5-572, V5-572G Battery Replacement: step 3, image 2 of 3 Acer Aspire V5-572, V5-572G Battery Replacement: step 3, image 3 of 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Battery Replacement: step 4, image 1 of 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Battery Replacement, Battery: step 5, image 1 of 1
    • Remove the single Phillips 0 screw securing the battery.
  6. Acer Aspire V5-572, V5-572G Battery Replacement: step 6, image 1 of 1
    • Remove the battery
4 other people completed this guide.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
One Comment
I plugged a wrong charger on my acer aspire v5 15-572 now it dosent charge what could be the problem
Joseph Musariri - Reply
Past 24 Hours: 1
Past 7 Days: 9
Past 30 Days: 27
All Time: 15,683
