Acer Aspire V5-572, V5-572G CMOS Battery Replacement
  1. Acer Aspire V5-572, V5-572G CMOS Battery Replacement, Bottom Cover: step 1, image 1 of 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G CMOS Battery Replacement: step 2, image 1 of 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G CMOS Battery Replacement: step 3, image 1 of 3 Acer Aspire V5-572, V5-572G CMOS Battery Replacement: step 3, image 2 of 3 Acer Aspire V5-572, V5-572G CMOS Battery Replacement: step 3, image 3 of 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G CMOS Battery Replacement: step 4, image 1 of 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G CMOS Battery Replacement, CMOS BIOS Battery: step 5, image 1 of 1
    • Lithium Battery tape CR 2032, 3V
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 9
Past 30 Days: 36
All Time: 6,989
