Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement
Video Overview
  1. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Bottom Cover: step 1, image 1 of 1
    • Switch-off the Laptop.
    • Remove the seventeen Philips #0 screws.
  2. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: step 2, image 1 of 1
    • If there is a plastic storage tray in the laptop, remove it.
  3. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: step 3, image 1 of 3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: step 3, image 2 of 3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: step 3, image 3 of 3
    • Starting from the SD Memory Card hole, start prying between the top and bottom cases.
    • Use plastic tools to avoid damaging the cover.
    • Remove the bottom case.
  4. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement: step 4, image 1 of 1
    • Disconnect the battery immediately for a safer repair.
    • Pull the battery connector away from the hard drive to disconnect it.
  5. Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: step 5, image 1 of 3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: step 5, image 2 of 3 Acer Aspire V5-572, V5-572G Wi-Fi half mini PCIe card Replacement, Wi-Fi half mini PCIe card: step 5, image 3 of 3
    • Remove 1x screw and disconnect the two antenna coaxial cables.
    • Remove the Wi-Fi card from the slot.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 11
Past 30 Days: 34
All Time: 4,582
