Acer Aspire V5-591G-75KE Fan and Heatsink Replacement
  1. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 1 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 2 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 3 of 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 2, image 1 of 2 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 2, image 2 of 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 3, image 1 of 2 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 3, image 2 of 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 4, image 1 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 4, image 2 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement, Fan and Heatsink: step 5, image 1 of 2 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement, Fan and Heatsink: step 5, image 2 of 2
    • Use a Phillips Head size #1 screwdriver to remove the two silver-colored 10mm Phillips Head screws securing the fan to the motherboard.
    • There are two screw holes, but you might only find one screw.
  6. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 6, image 1 of 2 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 6, image 2 of 2
    Buy
    • Use a pair of blunt tweezers to gently push on the 3-pin connector. This disconnects the fan from the motherboard.
    • You can lift up the fan if you need additional space to remove the connector.
  7. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 7, image 1 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 7, image 2 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 7, image 3 of 3
    • Use a Phillips #1 screwdriver to remove 6 black 10mm Phillips Head screws that connect the copper heat-sink to the motherboard.
  8. Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 8, image 1 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 8, image 2 of 3 Acer Aspire V5-591G-75KE Fan and Heatsink Replacement: step 8, image 3 of 3
    • Once you separate the heat-sink from the motherboard, you will need to clean and re-apply thermal compound. Do not proceed unless you are prepared and you have the necessary materials.
    • Using both hands, gently lift the heat-sink and fan components from the motherboard.
    • Old thermal compound can dry up and adhere the heat-sink to the motherboard like glue. This may make removing the fan and heat-sink difficult.
    • Do not re-seat the fan and heat-sink without cleaning and re-applying the thermal compound. For more information, please refer to this guide.
You can follow the steps in reverse to reassemble your device, but you should not re-seat the heat sink and fan without cleaning and re-applying the thermal compound.
Tasier Hagler
428 Reputation
4 Guides authored
UW Tacoma, Team S3-G5, Liner Fall 2017 Member of UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 21
All Time: 1,601
