Acer Aspire V5-591G-75KE Wireless Card Replacement
  1. Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 1 of 3 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 2 of 3 Acer Aspire V5-591G-75KE Wireless Card Replacement, Acer Aspire V5-591G-75KE Disassembly: step 1, image 3 of 3
    • Close down the display and flip the device upside down.
    • Use a Phillips #1 screwdriver to remove 18 black 10mm Phillips Head screws in order to loosen up the protective bottom casing.
  2. Acer Aspire V5-591G-75KE Wireless Card Replacement: step 2, image 1 of 2 Acer Aspire V5-591G-75KE Wireless Card Replacement: step 2, image 2 of 2
    • With the screws removed, flip the device right-side up and open up the display.
    • Run a plastic spudger tool along the seam of the face-plate in order to loosen up the protective bottom casing.
    • Popping sounds are normal, but forceful prying can damage delicate components. Be especially careful near the USB and HDMI ports.
  3. Acer Aspire V5-591G-75KE Wireless Card Replacement: step 3, image 1 of 2 Acer Aspire V5-591G-75KE Wireless Card Replacement: step 3, image 2 of 2
    • Close the display down once more, and flip the laptop upside down, with the hinge facing away from you.
    • Do not yank the bottom casing off. There is a small speaker wire that connects it to the motherboard.
    • Taking note of the small speaker wire, gently lift only the left side of the bottom casing.
  4. Acer Aspire V5-591G-75KE Wireless Card Replacement: step 4, image 1 of 3 Acer Aspire V5-591G-75KE Wireless Card Replacement: step 4, image 2 of 3 Acer Aspire V5-591G-75KE Wireless Card Replacement: step 4, image 3 of 3
    Tool used on this step:
    Buy
    • Using a pair of blunt tweezers, push on the tabs of the small white connector to separate it from the motherboard.
    • The entire bottom casing should lift with no resistance. If there is too much resistance, verify you removed all the screws, and run the plastic spudger tool around the face-plate again.
  5. Acer Aspire V5-591G-75KE Wireless Card Replacement, Wireless Card: step 5, image 1 of 1
    • Locate the wireless card on the top left quadrant. It should have two antenna cables connected to it, one white and one black.
  6. Acer Aspire V5-591G-75KE Wireless Card Replacement: step 6, image 1 of 1
    Buy
    • With a pair of blunt tweezers, firmly grasp each antenna head and detach it by lifting straight up.
    • The antenna cables are connected through small sockets. Small popping sounds when attaching and detaching the antennas are normal.
    • Note that the white cable connects on the top socket.
  7. Acer Aspire V5-591G-75KE Wireless Card Replacement: step 7, image 1 of 2 Acer Aspire V5-591G-75KE Wireless Card Replacement: step 7, image 2 of 2
    • Using a Phillip Head size 1 screwdriver, remove the screw attaching the wireless card to the laptop frame.
    • To detach the wireless card, lift up slightly and pull away.
Tasier Hagler
428 Reputation
4 Guides authored
UW Tacoma, Team S3-G5, Liner Fall 2017 Member of UW Tacoma, Team S3-G5, Liner Fall 2017
UWT-LINER-F17S3G5
4 Members
18 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 21
All Time: 1,286
