Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement
  1. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: step 1, image 1 of 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: step 1, image 2 of 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Back Cover: step 1, image 3 of 3
    • Remove the two 6mm JIS #0 screws from either side of the hinges.
  2. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 2, image 1 of 1
    • Remove the eight 4mm JIS #0 screws from the back cover.
  3. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 3, image 1 of 2 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 3, image 2 of 2
    • Insert an opening pick between the back panel and the sides of the computer to begin lifting the back off.
    • There are several clips holding the cover in place.
    • After the sides have been lifted, use the opening tool to finish opening the back cover.
  4. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 4, image 1 of 1
    • Lift off the back cover.
  5. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: step 5, image 1 of 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: step 5, image 2 of 3 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Battery: step 5, image 3 of 3
    • Remove the two JIS #0 screws that connect the battery to the rest of the laptop.
  6. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 6, image 1 of 2 Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 6, image 2 of 2
    • Pull the white tab connected to the battery out of the black tab that connects to the motherboard.
    • It is extremely important that this is done carefully and slowly to avoid causing damage to the motherboard.
  7. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 7, image 1 of 1
    • Lift the battery out gently.
  8. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement, Trackpad: step 8, image 1 of 1
    • Remove the strip of tape that secures the motherboard connector to the track pad.
  9. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 9, image 1 of 1
    • Unclip the motherboard connector from the track pad.
  10. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 10, image 1 of 1
    • Remove the strip of electrical tape from across the top of the track pad.
  11. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 11, image 1 of 1
    • Remove three 4 mm JIS #0 screws from the top of the track pad.
  12. Acer Chromebook 14 CB3-431-C3WS Trackpad Replacement: step 12, image 1 of 1
    • Lift the laptop base and the track pad will come out from the front of the laptop.
2 other people completed this guide.
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 17
All Time: 969
