Acer Chromebook 15 CB5-571-C09S Back Cover Replacement
  1. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement, Back Cover: step 1, image 1 of 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: step 2, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: step 2, image 2 of 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: step 3, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: step 4, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Back Cover Replacement: step 4, image 2 of 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
2 other people completed this guide.
Sakiynah Howard
1,000 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 612
