Acer Chromebook 15 CB5-571-C09S Battery Replacement
  1. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Back Cover: step 1, image 1 of 1
    • Place the device on a flat surface faced down so that the fan vents are at the top of the device.
  2. Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 2, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 2, image 2 of 2
    • Unscrew the eighteen 6 mm PH0 Phillips head screws from the back of the device.
  3. Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 3, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 3, image 2 of 2
    • Use a plastic opening tool to pry open the back cover around the edges of the device.
    • Be careful not to crack or break the back cover of the device.
    • You will have to adjust the position of the device to pry it open along all the edges.
  4. Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 4, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 4, image 2 of 2
    • Stand the device up with the hinges on top and carefully pull apart the back cover from the device.
  5. Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: step 5, image 1 of 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: step 5, image 2 of 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement, Battery: step 5, image 3 of 3
    • The battery is the large black rectangle located in the bottom center of the device.
    • Unscrew the single black 5 mm PH00 Phillips head screw holding the battery in place located at the top right corner of the battery.
  6. Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 6, image 1 of 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 6, image 2 of 3 Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 6, image 3 of 3
    • Disconnect the battery connector from the motherboard using two plastic opening tools.
    • The battery connector is the white "plug" that connects the battery to the motherboard with rainbow colored wires attached to it.
    • Use two of the plastic opening tools on either edge of the battery connector and carefully pull out the battery connector out from the motherboard.
  7. Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 7, image 1 of 2 Acer Chromebook 15 CB5-571-C09S Battery Replacement: step 7, image 2 of 2
    • Once the battery has been disconnected from the motherboard it can easily be removed from the device.
    • Grab the top edge of the battery and carefully pull it up and out of the device towards you.
8 other people completed this guide.
Sakiynah Howard
1,000 Reputation
6 Guides authored
2 Comments
Where do you get the plastic opening tools
Kelly Robledo - Reply
Instructions were perfect. Used a putty knife to pry off the back
Naomi Harrison - Reply
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 5
All Time: 4,113
