Acer Chromebook C710-2833 Hard Drive Replacement
Nicholas Latorre
Nicholas Latorre and 4 other contributors
Last updated on March 7, 2024
5 - 7 minutes
Easy
Introduction
Go to step 1
In this replacement guide, you will safely remove and install a hard drive.
  1. Acer Chromebook C710-2833 Hard Drive Replacement, Hard Drive: step 1, image 1 of 1
    • Flip your Chromebook over so the bottom is facing up.
  2. Acer Chromebook C710-2833 Hard Drive Replacement: step 2, image 1 of 2 Acer Chromebook C710-2833 Hard Drive Replacement: step 2, image 2 of 2
    • Locate the 6 mm Phillips #00 screw that holds the back cover together. Use your driver with the PH00 bit attached to unscrew it.
    • Once completely unscrewed, carefully lift the cover off.
    • Place the screw and cover safely to the side for now.
  3. Acer Chromebook C710-2833 Hard Drive Replacement: step 3, image 1 of 2 Acer Chromebook C710-2833 Hard Drive Replacement: step 3, image 2 of 2
    Tool used on this step:
    Anti-Static Wrist Strap
    $7.95
    • Now take your anti-static wrist strap and place it tightly on your wrist.
    • Attach the alligator clamp of the wrist strap to something that will ground yourself to avoid possible electric zaps.
    • The location chosen in the picture is recommended.
  4. Acer Chromebook C710-2833 Hard Drive Replacement: step 4, image 1 of 1
    • Locate the hard drive.
    • Locate the four 3 mm Phillips #00 screws on each corner of the hard drive.
    • Take your driver with the PH00 bit attached and unscrew all four screws.
    • Place the screws off to the side for now.
  5. Acer Chromebook C710-2833 Hard Drive Replacement: step 5, image 1 of 2 Acer Chromebook C710-2833 Hard Drive Replacement: step 5, image 2 of 2
    • Once all the screws are out, gently pull the hard drive out as pictured.
Nicholas Latorre
558 Reputation
5 Guides authored
USF Tampa, Team S1-G6, Nance Fall 2017 Member of USF Tampa, Team S1-G6, Nance Fall 2017
USFT-NANCE-F17S1G6
4 Members
10 Guides authored
0 Comments
Past 24 Hours: 2
Past 7 Days: 15
Past 30 Days: 41
All Time: 1,508
