Acer Chromebook C710-2856 Hard Drive Replacement
  1. Acer Chromebook C710-2856 Hard Drive Replacement, Removing Back Cover: step 1, image 1 of 2 Acer Chromebook C710-2856 Hard Drive Replacement, Removing Back Cover: step 1, image 2 of 2
    • Remove the one 4.3mm Phillips #1 screw holding the back cover on.
  2. Acer Chromebook C710-2856 Hard Drive Replacement, Unscrewing the Drive: step 2, image 1 of 1
    • Remove the four 2.8mm Phillips #000 screws holding the drive onto the case.
  3. Acer Chromebook C710-2856 Hard Drive Replacement, Uncovering the Pins: step 3, image 1 of 1
    • Gently pull the foam protector away from the pin connectors
  4. Acer Chromebook C710-2856 Hard Drive Replacement, Disconnecting the Drive: step 4, image 1 of 2 Acer Chromebook C710-2856 Hard Drive Replacement, Disconnecting the Drive: step 4, image 2 of 2
    • Gently pull the drive up and away to disconnect the hard drive from its seat
  5. Acer Chromebook C710-2856 Hard Drive Replacement, Removed Drive and Pieces: step 5, image 1 of 1
    • Fully removed hard drive, screws, and foam cover
Josh Rowell
146 Reputation
1 Guide authored
USF Tampa, Team S6-G5, Remmell Fall 2017 Member of USF Tampa, Team S6-G5, Remmell Fall 2017
USFT-REMMELL-F17S6G5
7 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 350
