Acer Chromebook C710-2856 Wi-Fi Card Replacement
  1. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Back Cover: step 1, image 1 of 2 Acer Chromebook C710-2856 Wi-Fi Card Replacement, Back Cover: step 1, image 2 of 2
    • Flip the device over and remove the 4.3 mm screw using a Phillips #1 screwdriver.
    • Remove the back cover.
  2. Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: step 2, image 1 of 3 Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: step 2, image 2 of 3 Acer Chromebook C710-2856 Wi-Fi Card Replacement, Wi-Fi Card: step 2, image 3 of 3
    • Using the Phillips #1 screwdriver, remove the screw from the Wi-Fi card.
    • Carefully remove the piece of tape to allow for more room to remove the Wi-Fi card.
    • Use the blue plastic opening tool to lift and remove the Wi-Fi card from its socket.
  3. Acer Chromebook C710-2856 Wi-Fi Card Replacement: step 3, image 1 of 3 Acer Chromebook C710-2856 Wi-Fi Card Replacement: step 3, image 2 of 3 Acer Chromebook C710-2856 Wi-Fi Card Replacement: step 3, image 3 of 3
    • Use the blue plastic opening tool and carefully remove the connectors from the Wi-Fi card.
  4. Acer Chromebook C710-2856 Wi-Fi Card Replacement: step 4, image 1 of 2 Acer Chromebook C710-2856 Wi-Fi Card Replacement: step 4, image 2 of 2
    • Remove the Wi-Fi card.
John
101 Reputation
1 Guide authored
USF Tampa, Team S6-G5, Remmell Fall 2017 Member of USF Tampa, Team S6-G5, Remmell Fall 2017
USFT-REMMELL-F17S6G5
7 Members
8 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 418
