Acer Chromebook C720 Solid State Drive (SSD) Replacement
  1. Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): step 1, image 1 of 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): step 1, image 2 of 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement, Solid State Drive (SSD): step 1, image 3 of 3
    • WARNING: Make sure your device is turned off before proceeding. If you proceed with the device on, the device may be damaged
    • Remove the thirteen 6mm screws using the Phillips #0 screwdriver.
    • Using the blue plastic case opener, unlatch the back of the case to expose the motherboard and other components.
  2. Acer Chromebook C720 Solid State Drive (SSD) Replacement: step 2, image 1 of 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: step 2, image 2 of 3 Acer Chromebook C720 Solid State Drive (SSD) Replacement: step 2, image 3 of 3
    • Remove the single 3mm screw holding the SSD with the Phillips #0 screwdriver.
  3. Acer Chromebook C720 Solid State Drive (SSD) Replacement: step 3, image 1 of 2 Acer Chromebook C720 Solid State Drive (SSD) Replacement: step 3, image 2 of 2
    • Gently remove the SSD from the motherboard.
5 other people completed this guide.
Benjamin Rahman
517 Reputation
3 Guides authored
IUPUI, Team S2-G5, Harley Spring 2019 Member of IUPUI, Team S2-G5, Harley Spring 2019
IUPUI-HARLEY-S19S2G5
4 Members
7 Guides authored
2 Comments
When you’re looking for a replacement drive, its socket is for a B-keyed m.2 2242 (22m x 42m). I haven’t actually found any just-B-keyed on the market, so you’ll probably end up getting B+M keyed (like the stock drive).
Another guide which goes further into recovering the OS to the new drive is here: https://www.androidcentral.com/how-upgra...
Matt Beary - Reply
Mi duda es como instalo Chrome os a la ssd nueva
José De Jesús Lopez Guillen - Reply
Past 24 Hours: 1
Past 7 Days: 27
Past 30 Days: 109
All Time: 6,563
