Acer Chromebook C720-2827 LED PCB Replacement
  1. Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: step 1, image 1 of 2 Acer Chromebook C720-2827 LED PCB Replacement, Back Panel Assembly: step 1, image 2 of 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 LED PCB Replacement: step 2, image 1 of 2 Acer Chromebook C720-2827 LED PCB Replacement: step 2, image 2 of 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 LED PCB Replacement, Battery: step 3, image 1 of 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 LED PCB Replacement: step 4, image 1 of 2 Acer Chromebook C720-2827 LED PCB Replacement: step 4, image 2 of 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 LED PCB Replacement: step 5, image 1 of 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: step 6, image 1 of 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: step 6, image 2 of 3 Acer Chromebook C720-2827 LED PCB Replacement, LED PCB: step 6, image 3 of 3
    • Use the Phillips #1 screwdriver to remove the two 3.1mm screws from the LED PCB.
    • Lift the LED PCB up with your fingers and flip it over revealing the ZIF connector.
    • The LED PCB is still tethered to the daughterboard via a ribbon cable so be sure not to yank it out or it could cause damage to the cable or its connectors.
  7. Acer Chromebook C720-2827 LED PCB Replacement: step 7, image 1 of 3 Acer Chromebook C720-2827 LED PCB Replacement: step 7, image 2 of 3 Acer Chromebook C720-2827 LED PCB Replacement: step 7, image 3 of 3
    • Set the LED PCB down and use your spudger to flip up the white bar of the ZIF connector.
    • Pull the ribbon cable out with your fingers.
Sarah Westberg
24,274 Reputation
71 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,095 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 250
