Acer Chromebook C720-2827 RAM Replacement
  1. Acer Chromebook C720-2827 RAM Replacement, Back Panel Assembly: step 1, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement, Back Panel Assembly: step 1, image 2 of 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 RAM Replacement: step 2, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 2, image 2 of 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 RAM Replacement, Battery: step 3, image 1 of 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 RAM Replacement: step 4, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 4, image 2 of 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 RAM Replacement: step 5, image 1 of 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 RAM Replacement, Speakers: step 6, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement, Speakers: step 6, image 2 of 2
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 RAM Replacement: step 7, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 7, image 2 of 2
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 RAM Replacement, Solid State Drive: step 8, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement, Solid State Drive: step 8, image 2 of 2
    • Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 RAM Replacement: step 9, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 9, image 2 of 2
    • Carefully pull out the solid state drive using two fingers.
  10. Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: step 10, image 1 of 3 Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: step 10, image 2 of 3 Acer Chromebook C720-2827 RAM Replacement, USB Port/SD Card Reader: step 10, image 3 of 3
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  11. Acer Chromebook C720-2827 RAM Replacement: step 11, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 11, image 2 of 2
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  12. Acer Chromebook C720-2827 RAM Replacement: step 12, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 12, image 2 of 2
    • Pull the blue tab on the ribbon cable to remove it.
  13. Acer Chromebook C720-2827 RAM Replacement: step 13, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 13, image 2 of 2
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  14. Acer Chromebook C720-2827 RAM Replacement: step 14, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 14, image 2 of 2
    • Position the spudger under the switch.
  15. Acer Chromebook C720-2827 RAM Replacement: step 15, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 15, image 2 of 2
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
  16. Acer Chromebook C720-2827 RAM Replacement, Motherboard: step 16, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement, Motherboard: step 16, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the four 3.0mm screws.
    • Loosen the six 3.0mm CPU screws using the Phillips #1 screwdriver.
    • The six 3.0mm CPU screws do not come out of the motherboard.
  17. Acer Chromebook C720-2827 RAM Replacement: step 17, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 17, image 2 of 2
    • Grab the wire for the two pin connector.
    • Pull the wire to disconnect it from the motherboard.
  18. Acer Chromebook C720-2827 RAM Replacement: step 18, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 18, image 2 of 2
    • Place the back of the spudger under the black wire that connects the wireless card to the motherboard.
    • Flick the spudger up to disconnect the cable from the motherboard.
  19. Acer Chromebook C720-2827 RAM Replacement: step 19, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 19, image 2 of 2
    • Place the back of the spudger under the white coaxial antenna wire that connects the wireless card to the motherboard.
  20. Acer Chromebook C720-2827 RAM Replacement: step 20, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 20, image 2 of 2
    • Take both wires and unravel them from the CPU fan.
  21. Acer Chromebook C720-2827 RAM Replacement: step 21, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 21, image 2 of 2
    • Firmly grasp the red, yellow, and white cords with two fingers.
    • Pull the cords to unplug it.
  22. Acer Chromebook C720-2827 RAM Replacement: step 22, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 22, image 2 of 2
    • Position the spudger under the switch of the big ribbon cable.
  23. Acer Chromebook C720-2827 RAM Replacement: step 23, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 23, image 2 of 2
    • Grab the blue tab of the ribbon cable.
    • Pull on the blue tab to disconnect the ribbon cable.
  24. Acer Chromebook C720-2827 RAM Replacement: step 24, image 1 of 3 Acer Chromebook C720-2827 RAM Replacement: step 24, image 2 of 3 Acer Chromebook C720-2827 RAM Replacement: step 24, image 3 of 3
    • Grab the red and black cable near the display cables, this is the cable to the other two pin connector.
    • Pull on the wire to disconnect it from the motherboard.
    • Flip the wire and the connector up to move it out of the way.
  25. Acer Chromebook C720-2827 RAM Replacement: step 25, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 25, image 2 of 2
    • Position the spudger under the switch for the smaller ribbon cable.
    • Flick the spudger up to flip the smaller switch up.
  26. Acer Chromebook C720-2827 RAM Replacement: step 26, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 26, image 2 of 2
    • Grab the blue tab on the ribbon cable.
    • Pull on the tab to disconnect the ribbon cable from the motherboard.
  27. Acer Chromebook C720-2827 RAM Replacement: step 27, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 27, image 2 of 2
    • Position the back of the spudger at the edge of the tape that holds the display cable in.
    • Peel the tape back so it is out of the way.
  28. Acer Chromebook C720-2827 RAM Replacement: step 28, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 28, image 2 of 2
    • Position the back of the spudger on the display cable.
    • Push the display cable out using the back of the spudger.
  29. Acer Chromebook C720-2827 RAM Replacement: step 29, image 1 of 2 Acer Chromebook C720-2827 RAM Replacement: step 29, image 2 of 2
    • Lift up the CPU fan to ensure that no wires are tangled. If the black and white wires are tangles please repeat step 5.
    • Lift up the other end of the motherboard to completely remove the motherboard.
  30. Acer Chromebook C720-2827 RAM Replacement, RAM: step 30, image 1 of 1
  31. Acer Chromebook C720-2827 RAM Replacement: step 31, image 1 of 1
    • Put the new RAM in place of the old RAM.
    • Carefully solder the new RAM into place.
Kennedy Morales
655 Reputation
6 Guides authored
2 Comments
Can you link the ram parts?
Tyler OHara - Reply
Very helpful
Asil Black - Reply
Past 24 Hours: 2
Past 7 Days: 8
Past 30 Days: 28
All Time: 3,943
