Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement
  1. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: step 1, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Back Panel Assembly: step 1, image 2 of 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 2, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 2, image 2 of 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Battery: step 3, image 1 of 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 4, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 4, image 2 of 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 5, image 1 of 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: step 6, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, Speakers: step 6, image 2 of 2
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 7, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 7, image 2 of 2
    • Carefully pull out the speakers from each side of the Chromebook.
  8. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: step 8, image 1 of 3 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: step 8, image 2 of 3 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement, USB Port/SD Card Reader: step 8, image 3 of 3
    • Remove the three 6.0mm screws using the Phillips #1 screwdriver.
    • Remove the two 3.0mm screws using the Phillips #1 screwdriver.
  9. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 9, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 9, image 2 of 2
    • Position the spudger under the switch that connects the ribbon cable to the motherboard.
    • Flick the spudger up to flip the switch up.
  10. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 10, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 10, image 2 of 2
    • Pull the blue tab on the ribbon cable to remove it.
  11. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 11, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 11, image 2 of 2
    • Grab the edges of each piece of circuitry that is included with the SD Card Reader and USB Port.
    • Pull each piece of circuitry out of the Chromebook and remove it from the device.
  12. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 12, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 12, image 2 of 2
    • Position the spudger under the switch.
  13. Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 13, image 1 of 2 Acer Chromebook C720-2827 SD Card Reader/USB Port Replacement: step 13, image 2 of 2
    • Pull on the blue tab of the ribbon cable to remove the ribbon cable.
    • Repeat the previous step and this step with the other ribbon cable that is attached to the SD Card Reader/USB Port.
Jason Bechtold
611 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 9
All Time: 325
