Acer Chromebook C720-2827 Solid State Drive Replacement
  1. Acer Chromebook C720-2827 Solid State Drive Replacement, Back Panel Assembly: step 1, image 1 of 2 Acer Chromebook C720-2827 Solid State Drive Replacement, Back Panel Assembly: step 1, image 2 of 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Solid State Drive Replacement: step 2, image 1 of 2 Acer Chromebook C720-2827 Solid State Drive Replacement: step 2, image 2 of 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Solid State Drive Replacement, Solid State Drive: step 3, image 1 of 2 Acer Chromebook C720-2827 Solid State Drive Replacement, Solid State Drive: step 3, image 2 of 2
    • Remove the single 3.0mm screw securing the solid state drive using a Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Solid State Drive Replacement: step 4, image 1 of 2 Acer Chromebook C720-2827 Solid State Drive Replacement: step 4, image 2 of 2
    • Carefully pull out the solid state drive using two fingers.
2 other people completed this guide.
Jason Bechtold
611 Reputation
5 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 603
