Acer Chromebook C720-2827 Speakers Replacement
  1. Acer Chromebook C720-2827 Speakers Replacement, Back Panel Assembly: step 1, image 1 of 2 Acer Chromebook C720-2827 Speakers Replacement, Back Panel Assembly: step 1, image 2 of 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Speakers Replacement: step 2, image 1 of 2 Acer Chromebook C720-2827 Speakers Replacement: step 2, image 2 of 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Speakers Replacement, Battery: step 3, image 1 of 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Speakers Replacement: step 4, image 1 of 2 Acer Chromebook C720-2827 Speakers Replacement: step 4, image 2 of 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Speakers Replacement: step 5, image 1 of 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Speakers Replacement, Speakers: step 6, image 1 of 2 Acer Chromebook C720-2827 Speakers Replacement, Speakers: step 6, image 2 of 2
    • Unplug the speaker wire from the motherboard.
  7. Acer Chromebook C720-2827 Speakers Replacement: step 7, image 1 of 2 Acer Chromebook C720-2827 Speakers Replacement: step 7, image 2 of 2
    • Carefully pull out the speakers from each side of the Chromebook.
Kennedy Morales
655 Reputation
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 7
All Time: 344
