Acer Chromebook C720-2827 Trackpad Replacement
  1. Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: step 1, image 1 of 2 Acer Chromebook C720-2827 Trackpad Replacement, Back Panel Assembly: step 1, image 2 of 2
    • Remove the thirteen 6.0mm screws on the back panel using your Phillips #1 screwdriver.
  2. Acer Chromebook C720-2827 Trackpad Replacement: step 2, image 1 of 2 Acer Chromebook C720-2827 Trackpad Replacement: step 2, image 2 of 2
    • Pry the back panel open with the plastic opening tool.
  3. Acer Chromebook C720-2827 Trackpad Replacement, Battery: step 3, image 1 of 1
    • Remove the two 6.0mm screws securing the battery with your Phillips #1 screwdriver.
  4. Acer Chromebook C720-2827 Trackpad Replacement: step 4, image 1 of 2 Acer Chromebook C720-2827 Trackpad Replacement: step 4, image 2 of 2
    • Carefully pull out the battery wire connected to the battery port.
  5. Acer Chromebook C720-2827 Trackpad Replacement: step 5, image 1 of 1
    • Slowly lift the battery to remove it from the Chromebook.
  6. Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: step 6, image 1 of 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: step 6, image 2 of 3 Acer Chromebook C720-2827 Trackpad Replacement, Trackpad: step 6, image 3 of 3
    • Using a spudger, pry up the locking bar of the ZIF connector on the trackpad and remove the ribbon cable.
  7. Acer Chromebook C720-2827 Trackpad Replacement: step 7, image 1 of 3 Acer Chromebook C720-2827 Trackpad Replacement: step 7, image 2 of 3 Acer Chromebook C720-2827 Trackpad Replacement: step 7, image 3 of 3
    • Peel off the clear plastic covering the screws.
    • Remove the five grey 2.5 mm screws securing the trackpad with a Phillips #1 screwdriver.
    • Remove another four silver 2.9mm Phillips #1 screws from the silver bracket atop the trackpad with your driver.
  8. Acer Chromebook C720-2827 Trackpad Replacement: step 8, image 1 of 2 Acer Chromebook C720-2827 Trackpad Replacement: step 8, image 2 of 2
    • Lift up the silver bracket.
    • Remove the trackpad by lifting it up from the case.
Austin Blakely
19,961 Reputation
53 Guides authored
iFixit Member of iFixit
Staff
140 Members
18,095 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 256
