Acer Chromebook C720-2844 Display Screen Replacement
  1. Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: step 1, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement, Display Screen: step 1, image 2 of 2
    • Unscrew and remove the 1 cm Phillips #00 screws from motherboard.
  2. Acer Chromebook C720-2844 Display Screen Replacement: step 2, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement: step 2, image 2 of 2
    • Unscrew and remove the 1 cm Phillips #00 screw that secures the solid state drive.
    • Lift and pull towards you to remove.
  3. Acer Chromebook C720-2844 Display Screen Replacement: step 3, image 1 of 1
    • Disconnect the 3 cables shown by pulling back evenly from both ends.
  4. Acer Chromebook C720-2844 Display Screen Replacement: step 4, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement: step 4, image 2 of 2
    • Unlock the cables shown by lifting the white tab on each.
    • Pull back on the blue tab to remove each cable from the motherboard.
  5. Acer Chromebook C720-2844 Display Screen Replacement: step 5, image 1 of 2 Acer Chromebook C720-2844 Display Screen Replacement: step 5, image 2 of 2
    • Remove the motherboard by shifting to the left and lifting up.
    • Unhook the black and white cables from underneath the motherboard.
  6. Acer Chromebook C720-2844 Display Screen Replacement: step 6, image 1 of 1
    • Unscrew and remove the 1 cm Phillips #00 screws from the display brackets.
    • Lift bracket to detach from the screen.
  7. Acer Chromebook C720-2844 Display Screen Replacement: step 7, image 1 of 1
    • Separate the screen from the shell.
Derek Zevalkink
145 Reputation
1 Guide authored
Gateway, Team 1-2, Pee Spring 2022 Member of Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 175
