Acer Chromebook C720-2844 Touch Pad Replacement
  1. Acer Chromebook C720-2844 Touch Pad Replacement, Battery: step 1, image 1 of 3 Acer Chromebook C720-2844 Touch Pad Replacement, Battery: step 1, image 2 of 3 Acer Chromebook C720-2844 Touch Pad Replacement, Battery: step 1, image 3 of 3
    • Flip to the back cover of the laptop.
    • Remove the 1 cm Phillips #00 screws on the back cover.
    • Use pry tools to remove the back cover.
  2. Acer Chromebook C720-2844 Touch Pad Replacement: step 2, image 1 of 1
    • Take out your Phillips #00 screwdriver.
    • Remove the 1 cm screws of the battery. There are two of screws, one is on the left of the battery and the other is on the right. (circled in red).
  3. Acer Chromebook C720-2844 Touch Pad Replacement: step 3, image 1 of 2 Acer Chromebook C720-2844 Touch Pad Replacement: step 3, image 2 of 2
    • Unplug the battery from the motherboard by pulling the bundled cable connector free.
    • Lift the top part of battery.
    • Slide the battery forward to remove it completely from the motherboard.
  4. Acer Chromebook C720-2844 Touch Pad Replacement, Touch Pad: step 4, image 1 of 1
    • Lift white tab holding connector.
    • Pull from blue tab to disconnect.
  5. Acer Chromebook C720-2844 Touch Pad Replacement: step 5, image 1 of 1
    • Unscrew and remove the four 1 cm Phillips #00 screws under transparent cover.
  6. Acer Chromebook C720-2844 Touch Pad Replacement: step 6, image 1 of 2 Acer Chromebook C720-2844 Touch Pad Replacement: step 6, image 2 of 2
    • Unscrew and remove the two 1 cm Phillips #00 screws that secure the touchpad bracket.
    • Lift bracket to remove from touchpad.
  7. Acer Chromebook C720-2844 Touch Pad Replacement: step 7, image 1 of 1
    • Remove the tape securing the touchpad to the shell.
  8. Acer Chromebook C720-2844 Touch Pad Replacement: step 8, image 1 of 1
    • Lift and remove touchpad.
Christian Madrigal
229 Reputation
2 Guides authored
Gateway, Team 1-2, Pee Spring 2022 Member of Gateway, Team 1-2, Pee Spring 2022
GCC-PEE-S22S1G2
4 Members
4 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 144
