Acer Chromebook C740-C4PE Battery Replacement
  1. Acer Chromebook C740-C4PE Battery Replacement, Battery: step 1, image 1 of 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: step 1, image 2 of 3 Acer Chromebook C740-C4PE Battery Replacement, Battery: step 1, image 3 of 3
    • Make sure the laptop is turned off and unplugged before starting.
    • Unscrew the thirteen 10mm screws on the back of the computer using the Phillips #0 screwdriver.
    • Using the spudger or other prying tool, gently pry the back off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Battery Replacement: step 2, image 1 of 1
    • Unscrew the two 5mm battery screws using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Battery Replacement: step 3, image 1 of 1
    • Gently lift the battery up and away from the hooks on the bottom of the device keeping the battery in place.
    • Be sure the battery is away from the clips before pulling away so as not to break the clips.
  4. Acer Chromebook C740-C4PE Battery Replacement: step 4, image 1 of 3 Acer Chromebook C740-C4PE Battery Replacement: step 4, image 2 of 3 Acer Chromebook C740-C4PE Battery Replacement: step 4, image 3 of 3
    • Detach the connecting cable from the motherboard by pulling away.
    • Remove the battery from the device.
3 other people completed this guide.
Jacob Kahn
273 Reputation
2 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 6
All Time: 499
