Acer Chromebook C740-C4PE Heatsink Replacement
  1. Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: step 1, image 1 of 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: step 1, image 2 of 3 Acer Chromebook C740-C4PE Heatsink Replacement, Heatsink: step 1, image 3 of 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the thirteen 10mm screws on the back of the device using a Phillips #0 screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Heatsink Replacement: step 2, image 1 of 2 Acer Chromebook C740-C4PE Heatsink Replacement: step 2, image 2 of 2
    • Remove the four 5mm screws on the heatsink using the Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Heatsink Replacement: step 3, image 1 of 2 Acer Chromebook C740-C4PE Heatsink Replacement: step 3, image 2 of 2
    • Loosen the two Phillips-head screws on the fan attached to the heatsink.
  4. Acer Chromebook C740-C4PE Heatsink Replacement: step 4, image 1 of 1
    • Detach the two antennae cables from the WiFi card by gently pulling on them.
  5. Acer Chromebook C740-C4PE Heatsink Replacement: step 5, image 1 of 1
    • Gently pull the fan cable out of the motherboard.
    • Pulling too hard may break the wires or the connector itself.
  6. Acer Chromebook C740-C4PE Heatsink Replacement: step 6, image 1 of 1
    • Remove the cable routed through the fan.
    • Do not completely remove the cables as they are attached to the motherboard. Once they are no longer routed in the fan, leave them as they are.
  7. Acer Chromebook C740-C4PE Heatsink Replacement: step 7, image 1 of 1
    • Remove the heatsink from the motherboard.
    • Before changing the heatsink/fan, you must clean off the thermal paste from the CPU and apply new thermal paste.
Dylan Tocci
237 Reputation
2 Guides authored
One Comment
What type of thermal paste is best used?
Tracey Arria - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 6
All Time: 371
