Acer Chromebook C740-C4PE Solid State Drive Replacement
  1. Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: step 1, image 1 of 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: step 1, image 2 of 3 Acer Chromebook C740-C4PE Solid State Drive Replacement, Solid State Drive: step 1, image 3 of 3
    • Make sure the laptop is turned off and laid down on a flat surface.
    • Unscrew the 13 screws on the back of the device using a PH0 Phillips head screwdriver.
    • Use the spudger or any other prying tool to pry the back plate off of the device.
    • Be sure not to pry too hard as it may result in snapping the back plate.
  2. Acer Chromebook C740-C4PE Solid State Drive Replacement: step 2, image 1 of 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: step 2, image 2 of 3 Acer Chromebook C740-C4PE Solid State Drive Replacement: step 2, image 3 of 3
    • Remove the 3.75 mm screw with a Phillips #0 screwdriver.
  3. Acer Chromebook C740-C4PE Solid State Drive Replacement: step 3, image 1 of 1
    • Pull the Solid State Drive out of the connector.
Sang Huynh
252 Reputation
2 Guides authored
One Comment
There are 2 types of SSD drives, m-SATA and M.2. Which does C740 use?
Guy Scree - Reply
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 10
All Time: 783
