Acer Chromebook CB3-111-C670 Battery Replacement
  1. Acer Chromebook CB3-111-C670 Battery Replacement, Battery: step 1, image 1 of 1
    • Be sure to have completely shut down the device before attempting to open it.
    • Remove the twelve Phillips #00 screws.
  2. Acer Chromebook CB3-111-C670 Battery Replacement: step 2, image 1 of 1
    • Insert a prying tool in between the top and bottom pieces of the laptop case to pry them apart but *do not remove the lower case*.
    • Carefully open the case to the left to avoid ripping the interior ribbon cable.
  3. Acer Chromebook CB3-111-C670 Battery Replacement: step 3, image 1 of 1
    • Pull the battery connector cable towards the battery to disconnect it.
  4. Acer Chromebook CB3-111-C670 Battery Replacement: step 4, image 1 of 1
    • Remove the battery.
6 other people completed this guide.
Tony
459 Reputation
2 Guides authored
USF Tampa, Team 10-5, Remmell Spring 2016 Member of USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Members
8 Guides authored
One Comment
Off topic and everything but how can i fix the audio jack? My audio jack is so worn it wont play sound
Daichi Potato - Reply
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 17
All Time: 4,134
