Acer Chromebook CB3-111-C670 Screen Replacement
  1. Acer Chromebook CB3-111-C670 Screen Replacement, Screen: step 1, image 1 of 2 Acer Chromebook CB3-111-C670 Screen Replacement, Screen: step 1, image 2 of 2
    • Unplug and power off the laptop before starting this repair.
    • Pry the white frame away from the screen with an opening tool.
    • As you move the spudger along the seam between the frame and the screen, the clips holding the frame in place will loosen.
  2. Acer Chromebook CB3-111-C670 Screen Replacement: step 2, image 1 of 2 Acer Chromebook CB3-111-C670 Screen Replacement: step 2, image 2 of 2
    • Remove the four screws within the silver brackets that are holding the screen to the back of the laptop.
  3. Acer Chromebook CB3-111-C670 Screen Replacement: step 3, image 1 of 1
    • Once you've removed the screws, lift the piece of tape that is covering the display connector.
    • Use a spudger to flip up the black tab on top of the connector to unlock the ZIF connector.
  4. Acer Chromebook CB3-111-C670 Screen Replacement: step 4, image 1 of 1
    Tool used on this step:
    Buy
    • Pull the ribbon cable out with tweezers and remove the screen.
9 other people completed this guide.
Allen Lewis
259 Reputation
1 Guide authored
USF Tampa, Team 10-5, Remmell Spring 2016 Member of USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Members
8 Guides authored
One Comment
Very easy. Thanks
johnqm123 - Reply
Past 24 Hours: 1
Past 7 Days: 7
Past 30 Days: 13
All Time: 5,132
