Acer Chromebook CB3-111-C670 WLAN Chip Replacement
  1. Acer Chromebook CB3-111-C670 WLAN Chip Replacement, WLAN Chip: step 1, image 1 of 1
    • Turn off your Chromebook and disconnect any charging cables.
    • Turn the Chromebook over so that the back panel with the Chromebook's serial number is facing upward.
    • Use the Phillips #000 screwdriver to remove the twelve screws from the back panel.
    • Use an opening tool to detach the back panel. Start at one of the four corners of the Chromebook and gently work around the edges. Insert it in the crease where the back panel and the main board meet. You should hear a slight click; this is the sound of the back panel detaching from the board.
    • Be careful not to apply too much force or you could damage the ribbon cable that connects the back panel to the motherboard.
    • Once you have detached the back panel, do not lift it vertically from the Chromebook. With the Chromebook facing in the direction as shown in the picture above, take the right hand side of the back panel and lift it toward the left, as if you are opening a book.
  2. Acer Chromebook CB3-111-C670 WLAN Chip Replacement: step 2, image 1 of 3 Acer Chromebook CB3-111-C670 WLAN Chip Replacement: step 2, image 2 of 3 Acer Chromebook CB3-111-C670 WLAN Chip Replacement: step 2, image 3 of 3
    • Disconnect the coaxial cables from the WLAN board located near the top left corner of the motherboard.
    • Grasp the top and bottom edge of the WLAN board using your fingers and gently disconnect it from the motherboard.
4 other people completed this guide.
lott
323 Reputation
1 Guide authored
USF Tampa, Team 10-5, Remmell Spring 2016 Member of USF Tampa, Team 10-5, Remmell Spring 2016
USFT-REMMELL-S16S10G5
3 Members
8 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 18
All Time: 1,784
