Acer Chromebook CB3-111-C8UB Audio Jack Replacement
  1. Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Back Panel Removal: step 1, image 1 of 2 Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Back Panel Removal: step 1, image 2 of 2
    • Position the laptop upside down with the hinges on the side furthest away from you.
    • Remove the eight 8mm screws with a phillips #1 screwdriver,
    • Remove the four 4.5mm screws with a phillips #1 screwdriver,
  2. Acer Chromebook CB3-111-C8UB Audio Jack Replacement: step 2, image 1 of 3 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: step 2, image 2 of 3 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: step 2, image 3 of 3
    • There is a wire connecting the two pieces of the laptop, from the inside, on the left, be careful not to damage it.
    • Use the plastic opening tool to pry open then remove the plastic base from the rest of the laptop. Start from the right side and work towards the left.
    • Set the plastic base beside the laptop by opening it as if you were opening a book.
  3. Acer Chromebook CB3-111-C8UB Audio Jack Replacement: step 3, image 1 of 2 Acer Chromebook CB3-111-C8UB Audio Jack Replacement: step 3, image 2 of 2
    • Flip up the small white ZIF connector by using a fingernail or metal spudger.
    • Pull the blue tab to remove the ribbon cable.
    • The ribbon cable is adhered to the plastic so it will take a little bit of force to remove it.
  4. Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Audio Jack: step 4, image 1 of 2 Acer Chromebook CB3-111-C8UB Audio Jack Replacement, Audio Jack: step 4, image 2 of 2
    • Remove the three 4.5mm screws using a phillips #1 screwdriver.
    • Now remove the chip.
Ryan Locatelli
161 Reputation
1 Guide authored
Cal Poly, Team 22-7, Maness Winter 2017 Member of Cal Poly, Team 22-7, Maness Winter 2017
CPSU-MANESS-W17S22G7
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 904
