Acer Chromebook CB3-131-C3KD Speakers Replacement
  1. Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: step 1, image 1 of 2 Acer Chromebook CB3-131-C3KD Speakers Replacement, Battery: step 1, image 2 of 2
    • Make sure you turn off the laptop before starting.
    • Unscrew and remove the (11) eleven 4mm J0 head screws on the underside of the laptop using the JIS #0 screwdriver.
  2. Acer Chromebook CB3-131-C3KD Speakers Replacement: step 2, image 1 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 2, image 2 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 2, image 3 of 3
    • Use the plastic opening tool to remove the back cover.
    • Be careful not to damage the ribbon cable connecting the back cover to the laptop.
  3. Acer Chromebook CB3-131-C3KD Speakers Replacement: step 3, image 1 of 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 3, image 2 of 2
    • Unscrew the (2) two 3mm J0 Phillips head screws that hold the battery in place.
  4. Acer Chromebook CB3-131-C3KD Speakers Replacement: step 4, image 1 of 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 4, image 2 of 2
    • Disconnect the battery from the motherboard.
    • Carefully disconnect the cable parallel to the board, not at an angle. Otherwise, you could damage the port.
  5. Acer Chromebook CB3-131-C3KD Speakers Replacement: step 5, image 1 of 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 5, image 2 of 2
    • Carefully lift the battery from one side, and then lift it out of the laptop.
  6. Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: step 6, image 1 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: step 6, image 2 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement, Speakers: step 6, image 3 of 3
    • Disconnect the three ribbon cables from the motherboard.
  7. Acer Chromebook CB3-131-C3KD Speakers Replacement: step 7, image 1 of 2 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 7, image 2 of 2
    • Unplug the cable by putting both thumbs on each tab and unlocking the cable by pushing the tabs away.
  8. Acer Chromebook CB3-131-C3KD Speakers Replacement: step 8, image 1 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 8, image 2 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 8, image 3 of 3
    • Remove speakers by placing index finger on top and thumb on bottom of the speakers.
    • Peel speakers away from the base that is connected by an adhesive.
  9. Acer Chromebook CB3-131-C3KD Speakers Replacement: step 9, image 1 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 9, image 2 of 3 Acer Chromebook CB3-131-C3KD Speakers Replacement: step 9, image 3 of 3
    • Peel the black cord connecting the two speakers together away from the Velcro located at the midpoint between the two speakers.
    • Remove speakers from laptop.
Johnathan
216 Reputation
2 Guides authored
USF Tampa, Team S11-G1, Passmore Fall 2017 Member of USF Tampa, Team S11-G1, Passmore Fall 2017
USFT-PASSMORE-F17S11G1
3 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 348
