Acer Chromebook CB3-431-C5EX Speaker Replacement
  1. Acer Chromebook CB3-431-C5EX Speaker Replacement, Bottom Panel: step 1, image 1 of 1
    • Working on your device while it is turned on may result in electric shock. Make sure to shut down and unplug your device before you begin.
    • Turn device over so the bottom panel is facing you.
  2. Acer Chromebook CB3-431-C5EX Speaker Replacement: step 2, image 1 of 1
    • Remove the eight 4mm Phillips #0 screws.
    • Remove the two 6mm Phillips #0 screws.
  3. Acer Chromebook CB3-431-C5EX Speaker Replacement: step 3, image 1 of 2 Acer Chromebook CB3-431-C5EX Speaker Replacement: step 3, image 2 of 2
    • Insert a plastic opening tool into the crack between the bottom panel and the side of the computer.
    • Gently pry the panel off the computer by continuously pulling up and on the panel and moving the plastic opening tool around the crack until the panel comes off.
    • There are several clips holding the cover in place.
    • Remove the bottom panel and set it aside.
  4. Acer Chromebook CB3-431-C5EX Speaker Replacement, Internal Speakers: step 4, image 1 of 1
    • Remove the two 4mm Phillips #0 screws securing the speaker.
  5. Acer Chromebook CB3-431-C5EX Speaker Replacement: step 5, image 1 of 2 Acer Chromebook CB3-431-C5EX Speaker Replacement: step 5, image 2 of 2
    • Remove the speaker from the computer.
    • Repeat the previous steps to remove the second speaker from the computer.
    • Note that the two speakers are connected by a wire, so you must replace both of them.
  6. Acer Chromebook CB3-431-C5EX Speaker Replacement: step 6, image 1 of 2 Acer Chromebook CB3-431-C5EX Speaker Replacement: step 6, image 2 of 2
    • Disconnect the speaker wire from the circuit board by grabbing the plug by its plastic edges and gently pulling it straight out.
Cayley Ho
545 Reputation
3 Guides authored
Cal Poly, Team S17-G3, Banghart Spring 2017 Member of Cal Poly, Team S17-G3, Banghart Spring 2017
CPSU-BANGHART-S17S17G3
5 Members
10 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 7
All Time: 1,028
