Acer Chromebook CB3-532-C47C Battery Replacement
  1. Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: step 1, image 1 of 2 Acer Chromebook CB3-532-C47C Battery Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Battery Replacement: step 2, image 1 of 2 Acer Chromebook CB3-532-C47C Battery Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Battery Replacement, Remove the battery cable: step 3, image 1 of 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Battery Replacement, Battery: step 4, image 1 of 2 Acer Chromebook CB3-532-C47C Battery Replacement, Battery: step 4, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook CB3-532-C47C Battery Replacement: step 5, image 1 of 1
    • Remove the battery from the laptop.
For optimal performance, after completing this guide, calibrate your newly installed battery.
3 other people completed this guide.
Sadie Brown
967 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 45
Past 30 Days: 101
All Time: 1,520
