Acer Chromebook CB3-532-C47C Motherboard Replacement
  1. Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: step 1, image 1 of 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Motherboard Replacement: step 2, image 1 of 2 Acer Chromebook CB3-532-C47C Motherboard Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove the battery cable: step 3, image 1 of 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: step 4, image 1 of 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Unplug the WiFi Antenna Connectors: step 4, image 2 of 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: step 5, image 1 of 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: step 5, image 2 of 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, WiFi Card: step 5, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
  6. Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: step 6, image 1 of 2 Acer Chromebook CB3-532-C47C Motherboard Replacement, Disconnect the Speakers: step 6, image 2 of 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  7. Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: step 7, image 1 of 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: step 7, image 2 of 3 Acer Chromebook CB3-532-C47C Motherboard Replacement, Keyboard Cable: step 7, image 3 of 3
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  8. Acer Chromebook CB3-532-C47C Motherboard Replacement: step 8, image 1 of 3 Acer Chromebook CB3-532-C47C Motherboard Replacement: step 8, image 2 of 3 Acer Chromebook CB3-532-C47C Motherboard Replacement: step 8, image 3 of 3
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  9. Acer Chromebook CB3-532-C47C Motherboard Replacement: step 9, image 1 of 1
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  10. Acer Chromebook CB3-532-C47C Motherboard Replacement, Remove Motherboard: step 10, image 1 of 1
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
Sadie Brown
967 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 3
Past 7 Days: 7
Past 30 Days: 20
All Time: 631
