Acer Chromebook CB3-532-C47C Speaker Replacement
  1. Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: step 1, image 1 of 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook CB3-532-C47C Speaker Replacement: step 2, image 1 of 2 Acer Chromebook CB3-532-C47C Speaker Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook CB3-532-C47C Speaker Replacement, Remove the battery cable: step 3, image 1 of 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: step 4, image 1 of 2 Acer Chromebook CB3-532-C47C Speaker Replacement, Disconnect the Speakers: step 4, image 2 of 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  5. Acer Chromebook CB3-532-C47C Speaker Replacement, Speakers: step 5, image 1 of 1
    • Pry the right speaker up with your hand to remove.
  6. Acer Chromebook CB3-532-C47C Speaker Replacement: step 6, image 1 of 2 Acer Chromebook CB3-532-C47C Speaker Replacement: step 6, image 2 of 2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  7. Acer Chromebook CB3-532-C47C Speaker Replacement: step 7, image 1 of 1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
Sadie Brown
967 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 14
All Time: 152
