Acer Chromebook CB5-571-C5XU Battery Replacement
  1. Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: step 1, image 1 of 2 Acer Chromebook CB5-571-C5XU Battery Replacement, Bottom Case: step 1, image 2 of 2
    • Remove the following eighteen screws using a Phillips #0 screwdriver.
    • Make sure the Chromebook is unplugged and shut down, so no files are lost and there is no risk of electrocution.
  2. Acer Chromebook CB5-571-C5XU Battery Replacement: step 2, image 1 of 2 Acer Chromebook CB5-571-C5XU Battery Replacement: step 2, image 2 of 2
    • Using the flat side of the spudger, pry open the bottom case of the laptop.
    • Working from the front to the back, where it connects to the screen, proved to be the easiest way of popping the case off.
  3. Acer Chromebook CB5-571-C5XU Battery Replacement, Battery: step 3, image 1 of 1
    • Using a Phillips #0 screwdriver, unscrew the screw on right side of the battery placement.
    • Be careful not to lose the screw and have a small container nearby to place it in.
  4. Acer Chromebook CB5-571-C5XU Battery Replacement: step 4, image 1 of 1
    • Using a plastic opening tool, disconnect the wires connecting the battery to the motherboard.
  5. Acer Chromebook CB5-571-C5XU Battery Replacement: step 5, image 1 of 1
    • Gently lift the battery out and remove it from the laptop casing.
To reassemble your device, follow these guidelines in reverse order.
3 other people completed this guide.
Kenneth Bowers
1,381 Reputation
7 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 10
All Time: 824
