Acer Chromebook R11 C738T-C44Z Battery Replacement
  1. Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: step 1, image 1 of 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: step 1, image 2 of 3 Acer Chromebook R11 C738T-C44Z Battery Replacement, Back Cover: step 1, image 3 of 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: step 2, image 1 of 2 Acer Chromebook R11 C738T-C44Z Battery Replacement, Battery: step 2, image 2 of 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Battery Replacement: step 3, image 1 of 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Battery Replacement: step 4, image 1 of 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
To reassemble your device, follow step one and two in reverse order.
Christopher Trinidad
316 Reputation
2 Guides authored
Gateway, Team 1-4, Saknee Fall 2021 Member of Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 11
All Time: 481
