Acer Chromebook R11 C738T-C44Z Speakers Replacement
  1. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: step 1, image 1 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: step 1, image 2 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Back Cover: step 1, image 3 of 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: step 2, image 1 of 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Battery: step 2, image 2 of 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 3, image 1 of 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 4, image 1 of 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: step 5, image 1 of 2 Acer Chromebook R11 C738T-C44Z Speakers Replacement, Speakers: step 5, image 2 of 2
    • Gently remove the LED Board Ribbon connected to the mother board.
  6. Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 6, image 1 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 6, image 2 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 6, image 3 of 3
    • Gently pry up speaker up using a spudger or opening tool to remove it.
    • It has an adhesive, so you might have to use some force.
    • Screwdrivers should not be used as prying tools and could cause damage to delicate components.
    • Repeat the same process for the other speaker.
  7. Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 7, image 1 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 7, image 2 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 7, image 3 of 3
    • Use the opening tool to unplug the speaker cable from the motherboard.
    • Disconnect the keyboard ribbon cable from the motherboard.
  8. Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 8, image 1 of 1
    • Using the opening tool to unlock and disconnect the touchpad cable.
  9. Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 9, image 1 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 9, image 2 of 3 Acer Chromebook R11 C738T-C44Z Speakers Replacement: step 9, image 3 of 3
    • Gently lift the speakers up and remove the cable from the system.
Connie Hernandez
517 Reputation
4 Guides authored
Gateway, Team 1-4, Saknee Fall 2021 Member of Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 6
All Time: 121
