Acer Chromebook R11 C738T-C44Z Touchpad Replacement
  1. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: step 1, image 1 of 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: step 1, image 2 of 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Back Cover: step 1, image 3 of 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: step 2, image 1 of 2 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Battery: step 2, image 2 of 2
    • Unplug the battery connector from the motherboard. (The motherboard is a group of wires in rainbow colors)
    • Use a Phillips #1 screwdriver to remove the two 3 mm screws, (one on each side of the battery), that secure it in place.
  3. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: step 3, image 1 of 1
    • Remove battery from its holder by pulling it upwards from the device
    • Attempt to remove it as gently as possible to avoid damaging the Motherboard
  4. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: step 4, image 1 of 1
    • Install the new battery and again use a Phillips #1 screwdriver to remove the two 3 mm screws
  5. Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: step 5, image 1 of 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: step 5, image 2 of 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement, Touchpad: step 5, image 3 of 3
    • Use a Phillips #1 screwdriver to remove the three 3 mm screws that secure the touchpad.
    • Lift up the tab for the cable cord.
    • Pull out the touchpad connector.
  6. Acer Chromebook R11 C738T-C44Z Touchpad Replacement: step 6, image 1 of 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: step 6, image 2 of 3 Acer Chromebook R11 C738T-C44Z Touchpad Replacement: step 6, image 3 of 3
    • Pull the left piece of tape up by prying it up with your fingers or with the screwdriver.
    • Be gentle to not rip the tape.
    • Next, pull up the other piece of tape.
    • Remove the touchpad.
Connie Hernandez
517 Reputation
4 Guides authored
Gateway, Team 1-4, Saknee Fall 2021 Member of Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Members
6 Guides authored
One Comment
Thank you, Connie Fernandez. ~Super
Super - Reply
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 7
All Time: 332
