Acer Chromebook R11 C738T-C44Z Wireless Card Replacement
  1. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: step 1, image 1 of 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: step 1, image 2 of 3 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Back Cover: step 1, image 3 of 3
    • Lay the laptop with the back side up.
    • Use a Phillips #1 screwdriver to remove eleven 3 mm screws.
    • Use the opening tool to pry the back cover off gently by placing it in the seam and working your way around the perimeter.
  2. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: step 2, image 1 of 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement, Wireless Card: step 2, image 2 of 2
    • Disconnect the two antenna cables (one black and one white) that are attached to the wireless card.
  3. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: step 3, image 1 of 1
    • Use a Phillips #1 screwdriver to remove the single 3 mm screw that secures the wireless card.
  4. Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: step 4, image 1 of 2 Acer Chromebook R11 C738T-C44Z Wireless Card Replacement: step 4, image 2 of 2
    • Carefully slide the wireless card out of its socket from the motherboard.
Connie Hernandez
517 Reputation
4 Guides authored
Gateway, Team 1-4, Saknee Fall 2021 Member of Gateway, Team 1-4, Saknee Fall 2021
GCC-SAKNEE-F21S1G4
4 Members
6 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 10
All Time: 344
