Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement
  1. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, Bottom Panel: step 1, image 1 of 1
    • Using a Phillips screwdriver, remove all eleven 7.0 mm screws from the bottom of the Chromebook.
  2. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: step 2, image 1 of 1
    • Find the seam along the edge of the device.
    • Wedge a finger into the groove and separate the panel from the device. If necessary, use a spudger.
    • The panel will still be connected to the device by internal wiring, so pull it off with some caution. It is best to flip the panel to the side once the seam has been broken.
  3. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: step 3, image 1 of 2 Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement, LED Board: step 3, image 2 of 2
    Tool used on this step:
    Buy
    • Use the flat end of the spudger to lift the retaining flap on the LED board ZIF connector.
    • Pull the ribbon cable from the ZIF connector using tweezers.
  4. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: step 4, image 1 of 1
    • Remove the 4.5 mm Phillips screw.
    • There is a magnet near the LED chip that might attract the screw.
  5. Acer Chromebook R11 CB5-132T-C1LK LED BoardReplacement: step 5, image 1 of 1
    • Use tweezers to remove the LED board.
Alan Shan
382 Reputation
3 Guides authored
Cal Poly, Team S23-G2, Livingston Spring 2017 Member of Cal Poly, Team S23-G2, Livingston Spring 2017
CPSU-LIVINGSTON-S17S23G2
4 Members
12 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 17
Past 30 Days: 23
All Time: 1,011
