Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement
  1. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Back Panel: step 1, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 2, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the battery cable: step 3, image 1 of 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Battery: step 4, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Battery: step 4, image 2 of 2
    • Using the Phillips #1 screwdriver, remove the two black 5.5 mm screws securing the battery.
  5. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 5, image 1 of 1
    • Remove the battery from the laptop.
  6. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Unplug the WiFi Antenna Connectors: step 6, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Unplug the WiFi Antenna Connectors: step 6, image 2 of 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  7. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the Black WiFi Wire: step 7, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the Black WiFi Wire: step 7, image 2 of 2
    • Deroute the black wifi wire from its slot in the palm rest.
  8. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the White WiFi Wire: step 8, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Deroute the White WiFi Wire: step 8, image 2 of 2
    • Deroute the white wifi wire from the slot in the palm rest.
  9. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: step 9, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: step 9, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Display Cable: step 9, image 3 of 3
    • Pull the end of the display cable attached to the motherboard straight up to remove.
    • Rotate the cable out away from the motherboard.
  10. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Right Hinge Screws: step 10, image 1 of 1
    • Remove the two screws from the right hinge.
  11. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 11, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 11, image 2 of 2
    • Insert a screwdriver or spudger under the hinge to get it started then rotate it open by hand as far as possible.
  12. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Left Hinge Screws: step 12, image 1 of 1
    • Remove the two screws from the left hinge.
  13. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 13, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 13, image 2 of 2
  14. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: step 14, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: step 14, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the display assembly: step 14, image 3 of 3
    • Lift the palm rest assembly from the front then slide it away from the hinges slightly to remove the assembly from the display.
  15. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Touchpad: step 15, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Touchpad: step 15, image 2 of 2
    • Flip up the retaining latch securing the touchpad cable to the motherboard.
  16. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 16, image 1 of 1
    • Pull the ribbon from the motherboard laterally off the touchpad.
  17. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 17, image 1 of 1
    • Using the Phillips #1 screwdriver, remove the three 3.2 mm screws holding the touchpad to the laptop.
  18. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 18, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 18, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 18, image 3 of 3
    • Carefully lift up on the keyboard ribbon cable and the insulating sheet immediately below it so the touchpad can clear them.
    • Lift the touchpad slightly from the top.
    • Pull the touchpad toward the motherboard as you continue to lift it, sliding it out from under the retaining fingers at the bottom.
  19. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 19, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 19, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 19, image 3 of 3
    • Remove the touchpad.
    • When reinstalling:
    • Make sure the touchpad goes underneath the two retaining fingers when reinstalling it.
    • The touchpad is correctly aligned when the guide pins next to the left and right screws are inserted in the holes.
  20. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Speakers: step 20, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the Speakers: step 20, image 2 of 2
    • Pull the black ribbon attached to the speakers out of the motherboard.
  21. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Speakers: step 21, image 1 of 1
    • Pry the right speaker up with your hand to remove.
  22. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 22, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 22, image 2 of 2
    • Thread the speaker under the black ribbon towards the left to allow removal of the left speaker.
  23. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 23, image 1 of 1
    • Pry up the left speaker to remove it.
    • Remove both speakers.
  24. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: step 24, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: step 24, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard Cable: step 24, image 3 of 3
    • Peel the yellow tape off the black keyboard ribbon cable on the motherboard.
    • Use a spudger to slide the black tabs on either side of the connector forward slightly.
    • Pull the black ribbon straight towards you to remove it from the motherboard.
  25. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 25, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 25, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 25, image 3 of 3
    • Flip up the tabs over the two white ribbons on the left using your finger.
    • For more information on Zero Insertion Force (ZIF) connectors, please visit this guide.
    • Pull the ribbons out of the motherboard by the blue tabs.
  26. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 26, image 1 of 1
    • Using the Phillips #1 screwdriver, remove four 6 mm screws.
    • Using the same Phillips #1 screwdriver, remove five 3 mm screws securing the metal plate to the motherboard.
  27. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove Motherboard: step 27, image 1 of 1
    • Remove the metal plate over the motherboard.
    • Remove the motherboard.
  28. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED Cable: step 28, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED Cable: step 28, image 2 of 2
    • Flip up the latch on the cable going from the I/O board to the LED board.
  29. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 29, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 29, image 2 of 2
    • Grasp the ribbon cable and pull it straight out to the right.
  30. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Motherboard Cable: step 30, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Motherboard Cable: step 30, image 2 of 2
    • Flip up the latch on the cable from the I/O board to the motherboard.
  31. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 31, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 31, image 2 of 2
    • Grasp the ribbon cable by the blue plastic reinforcement and pull the cable straight out to the right.
  32. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the Retaining Screw: step 32, image 1 of 1
    • Remove the single screw securing the I/O board.
  33. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 33, image 1 of 1
    • Remove the I/O board.
    • When reinstalling, be sure the hinge goes above the I/O board, not below it.
  34. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the LED board: step 34, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Disconnect the LED board: step 34, image 2 of 2
    • Flip the retaining latch up with a spudger.
  35. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 35, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement: step 35, image 2 of 2
    • Pull the cable straight out away from the front of the computer.
  36. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: step 36, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: step 36, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED board: step 36, image 3 of 3
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
  37. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: step 37, image 1 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: step 37, image 2 of 3 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the I/O board cable: step 37, image 3 of 3
    • The cable between the I/O board and the motherboard is lightly adhered to the plastic insulator on the keyboard. Pull up from the right to free the cable from the adhesive.
  38. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED cable: step 38, image 1 of 2 Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Remove the LED cable: step 38, image 2 of 2
    • The LED cable runs from the LED board to the I/O daughter card. It is lightly adhered to the keyboard. Remove it by gently pulling it away from the keyboard.
  39. Acer Chromebook cb3-532-c47c Keyboard / Palm Rest Replacement, Keyboard has been removed: step 39, image 1 of 1
    • All components have now been removed from the keyboard / palm rest assembly.
Jerry Wheeler
61,046 Reputation
71 Guides authored
Oregonians Member of Oregonians
Community
8 Members
183 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 9
All Time: 246
