Acer Chromebook cb3-532-c47c LED Board Replacement
  1. Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: step 1, image 1 of 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c LED Board Replacement: step 2, image 1 of 2 Acer Chromebook cb3-532-c47c LED Board Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the battery cable: step 3, image 1 of 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: step 4, image 1 of 2 Acer Chromebook cb3-532-c47c LED Board Replacement, Disconnect the LED board: step 4, image 2 of 2
    • Flip the retaining latch up with a spudger.
  5. Acer Chromebook cb3-532-c47c LED Board Replacement: step 5, image 1 of 2 Acer Chromebook cb3-532-c47c LED Board Replacement: step 5, image 2 of 2
    • Pull the cable straight out away from the front of the computer.
  6. Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: step 6, image 1 of 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: step 6, image 2 of 3 Acer Chromebook cb3-532-c47c LED Board Replacement, Remove the LED board: step 6, image 3 of 3
    • Remove the single retaining screw securing the LED board.
    • Remove the board.
    • When reassembling, ensure the board is seated on the guide pin before reinstalling the retaining screw.
Jerry Wheeler
60,179 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
181 Guides authored
0 Comments
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 4
All Time: 74
