Acer Chromebook cb3-532-c47c WiFi Card Replacement
  1. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Back Panel: step 1, image 1 of 2 Acer Chromebook cb3-532-c47c WiFi Card Replacement, Back Panel: step 1, image 2 of 2
    • Power off the laptop before beginning the replacement.
    • Using the Phillips #1 screwdriver, remove eighteen 7 mm screws from the back panel of the device.
  2. Acer Chromebook cb3-532-c47c WiFi Card Replacement: step 2, image 1 of 2 Acer Chromebook cb3-532-c47c WiFi Card Replacement: step 2, image 2 of 2
    • Use a plastic opening tool around the edges of the laptop and remove the back panel from the device.
  3. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Remove the battery cable: step 3, image 1 of 1
    • Push on the sides of the connector with a plastic spudger to separate the cable from the motherboard.
  4. Acer Chromebook cb3-532-c47c WiFi Card Replacement, Unplug the WiFi Antenna Connectors: step 4, image 1 of 2 Acer Chromebook cb3-532-c47c WiFi Card Replacement, Unplug the WiFi Antenna Connectors: step 4, image 2 of 2
    • Firmly pull the end of the black wire attached to the Wi-Fi card upwards and remove it from the device.
    • Repeat with the white wire.
  5. Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: step 5, image 1 of 3 Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: step 5, image 2 of 3 Acer Chromebook cb3-532-c47c WiFi Card Replacement, WiFi Card: step 5, image 3 of 3
    • Using the Phillips #0 screwdriver, remove the single 6 mm screw securing the Wi-Fi card.
    • Pull the Wi-Fi card straight out of the motherboard and remove it from the device.
Jerry Wheeler
60,179 Reputation
69 Guides authored
Oregonians Member of Oregonians
Community
8 Members
181 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 4
All Time: 151
