Acer Extensa 4420 RAM Replacement
  1. Acer Extensa 4420 RAM Replacement, Battery: step 1, image 1 of 2 Acer Extensa 4420 RAM Replacement, Battery: step 1, image 2 of 2
    • First, make sure that the battery lock is turned off.
    • The battery lock makes it so the battery doesn't accidentally fall out of your computer while it is running.
  2. Acer Extensa 4420 RAM Replacement: step 2, image 1 of 3 Acer Extensa 4420 RAM Replacement: step 2, image 2 of 3 Acer Extensa 4420 RAM Replacement: step 2, image 3 of 3
    • Then, slide the other battery lock while pulling the battery out.
  3. Acer Extensa 4420 RAM Replacement, Back Panel: step 3, image 1 of 1
    Tool used on this step:
    Phillips #00 Screwdriver
    $5.49
    Buy
    • Unscrew all five screws on the back panel with a Phillips #00 screwdriver
    • The screws will stay in the back panel, so when you remove it, you don't have to worry about organizing the screws.
  4. Acer Extensa 4420 RAM Replacement: step 4, image 1 of 3 Acer Extensa 4420 RAM Replacement: step 4, image 2 of 3 Acer Extensa 4420 RAM Replacement: step 4, image 3 of 3
    Spudger
    $3.99
    Buy
    • Take a spudger and start to pry open the back panel. Finish prying it open with your hands.
    • Be extra careful and try not to break any clips in this process.
  5. Acer Extensa 4420 RAM Replacement, RAM: step 5, image 1 of 3 Acer Extensa 4420 RAM Replacement, RAM: step 5, image 2 of 3 Acer Extensa 4420 RAM Replacement, RAM: step 5, image 3 of 3
    • Push the clips in red towards the outside. Doing so will release the RAM. Pull the RAM out.
    • Do this for both RAM modules
TheMasterG
1,406 Reputation
12 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 11
All Time: 124
