Acer Iconia A1-810 Motherboard Replacement
  1. Acer Iconia A1-810 Motherboard Replacement, Battery: step 1, image 1 of 1
    • Remove the back cover by lifting with a plastic opening tool, below the camera button slot.
  2. Acer Iconia A1-810 Motherboard Replacement: step 2, image 1 of 1
    • Remove the black tape connecting the battery to the motherboard.
  3. Acer Iconia A1-810 Motherboard Replacement: step 3, image 1 of 1
    • Pinch the sides of the white resistor to safely remove it without damaging it or yourself.
  4. Acer Iconia A1-810 Motherboard Replacement: step 4, image 1 of 2 Acer Iconia A1-810 Motherboard Replacement: step 4, image 2 of 2
    • Remove battery from adhesive.
  5. Acer Iconia A1-810 Motherboard Replacement, Motherboard: step 5, image 1 of 1
    • Use a Phillips #000 screwdriver to remove the screws around the perimeter of the motherboard.
  6. Acer Iconia A1-810 Motherboard Replacement: step 6, image 1 of 2 Acer Iconia A1-810 Motherboard Replacement: step 6, image 2 of 2
    • Disconnect the resistor attached to the orange tab by sliding the tail out.
    • Pry open the orange tab near the top left corner.
  7. Acer Iconia A1-810 Motherboard Replacement: step 7, image 1 of 3 Acer Iconia A1-810 Motherboard Replacement: step 7, image 2 of 3 Acer Iconia A1-810 Motherboard Replacement: step 7, image 3 of 3
    Tool used on this step:
    Buy
    • Disconnect all cords, wires, and resistors from the motherboard using tweezers.
  8. Acer Iconia A1-810 Motherboard Replacement: step 8, image 1 of 3 Acer Iconia A1-810 Motherboard Replacement: step 8, image 2 of 3 Acer Iconia A1-810 Motherboard Replacement: step 8, image 3 of 3
    • Continue to disconnect all resistors attached from the motherboard, using tweezers.
  9. Acer Iconia A1-810 Motherboard Replacement: step 9, image 1 of 1
    • Gently lift motherboard out.
    • The edges may be sharp.
7 other people completed this guide.
John
635 Reputation
3 Guides authored
UWT Liner: Group 3 Member of UWT Liner: Group 3
Community
5 Members
3 Guides authored
8 Comments
I need main ic part num A1-810 iconia I need main ic
mehwish - Reply
It was damage because high voltage
mehwish - Reply
I need main ic
mehwish - Reply
Can you replace the mini USB charger port without replacing entire motherboard and losing data?
theblackfox2 - Reply
Hi there i need acer lconia A3 main bord how much it will cost me ?
Muhammad - Reply
Past 24 Hours: 1
Past 7 Days: 11
Past 30 Days: 25
All Time: 5,413
