Acer Iconia B1-711 Loudspeaker Replacement
Video Overview
  1. Acer Iconia B1-711 Loudspeaker Replacement, Back Cover: step 1, image 1 of 3 Acer Iconia B1-711 Loudspeaker Replacement, Back Cover: step 1, image 2 of 3 Acer Iconia B1-711 Loudspeaker Replacement, Back Cover: step 1, image 3 of 3
    • Switch-off the tablet.
    • Remove any SIM and/or Memory Card.
    • Start opening near to the Volume Up/Down buttons. It's more well to use a plastic opening tool to avoid damaging the cover.
    • When lifting the cover, be careful not to tear the Loudspeaker cable at the bottom right side.
    • Disconnect the Loudspeaker cable from the Logic board.
  2. Acer Iconia B1-711 Loudspeaker Replacement: step 2, image 1 of 2 Acer Iconia B1-711 Loudspeaker Replacement: step 2, image 2 of 2
    • Before doing anything, disconnect the battery.
  3. Acer Iconia B1-711 Loudspeaker Replacement, Loudspeaker: step 3, image 1 of 2 Acer Iconia B1-711 Loudspeaker Replacement, Loudspeaker: step 3, image 2 of 2
    • The loudspeaker is stuck on the Rear Cover with a double side tape.
    • Use a sharp tool remove it.
ZFix
192,056 Reputation
330 Guides authored
Master Techs Member of Master Techs
Community
321 Members
1,525 Guides authored
0 Comments
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 478
